It is currently Thu Aug 21, 2025 9:47 pm
PostPosted: Sat Oct 20, 2012 7:33 am
First name: Jeff
Last Name: VanZant
City: North Pole
State: Alaska
Zip/Postal Code: 99705
Hello, Just a question to throw out there to anyone, I have had a set of BRW sitting around a couple of months, and when I received it, it was a reddish-brick like, very pretty, but now that I have bent the sides and finished the box, the wood has taken on a darker tone,more chocolate to black in spots, still pretty, but I believe this to be oxidation right? My question is this, is there anyway or anything that will restore that reddish look before I seal the guitar without being to aggressive with sanding, or am I stuck with a darker
guitar than first thought?
Jeff
PostPosted: Sat Oct 20, 2012 8:23 am
Last Name: Kincheloe
Probably stuck with it. The finish won't prevent oxidation, so even if you do sand it back, it will just darken again later. It's called dalbergia nigra for a reason :)
PostPosted: Sat Oct 20, 2012 10:08 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I have experienced a similar problem with some of my BR that I cut in the late-1980's. It had oxidized to a reddish brown, but as soon as I sand it a bit, it gets the dark chocolate color.
The pleasant surprise is that the finished guitars have lightened up again, but it generally takes over a year.
PostPosted: Sat Oct 20, 2012 12:24 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
The same stuff happened to me (it was just a bridge blank, though).
PostPosted: Sat Oct 20, 2012 1:29 pm
First name: Jim
Last Name: Kirby
Tell the customs guys it's actually African Blackwood?
I have a set of CSA stumpwood that is very dark, verging on black, and I was recently sanding it to thickness and cleaning it up, and I like how it looks now. I certainly wouldn't fault it for color. It's not a pre-war martin or a nice classical, but its it's own thing. (Let's see how the sides bend, though).
Jim Kirby
kirby@udel.edu
PostPosted: Sat Oct 20, 2012 10:11 pm
If you have a scrap of the wood available you could try coating it with some liquid laundry detergent or dishwashing detergent, letting it sit for several minutes and then rinsing it throughly with water. I have done this with cocobolo and it does seem to lessen it's tendency to go black with age. The detergent pulls the oils out of the surface of the wood and can leave it washed out looking until a finish is applied. YMMV, so by all means test on a scrap of the wood you are using.
PostPosted: Wed Jun 26, 2013 5:15 pm
Last Name: Burchfield
City: Tallahassee
Zip/Postal Code: 32305
my back has several real light spots from the drying out during bending how do i even out the color
PostPosted: Wed Jun 26, 2013 6:30 pm
Last Name: Beaver
City: Lake Forest
Wish I had the problem. No BRW here :( :( :(
Joe Beaver
Maker of Sawdust
PostPosted: Wed Jun 26, 2013 7:06 pm
First name: Trevor
Last Name: Gore
City: Sydney
Sure is. The last BRW guitar I finished had a bit of colouring to it, which looked quite attractive, but under finish it's basically black. But a very nice black! Pic here.
http://www.goreguitars.com.au
